Back feed problem
Old Jun 20, 2006 | 09:55 PM
79camarols1's Avatar
Default Back feed problem
When the switch is pushed to off the car stays running. I've talked to painless,street&performance still can't solve the problem. I've tried diodes,lightbulbs on the exciter wire still did not fix the problem.
Here is my set up. Batt+ to batt terminal on switch opposit side of switch to starter.
Jumper from hot side of switch to small post on kill switch.
Opposite small terminal to maxi fuse then to alt post.
The L wire on plug gose to the exciter wire from the fuse box.
Fuse box has to power wires one to alt.post and the other to maxi fuse.
ECM to batt.
Can any one help with back feed problem.
Master switch is cole hersee #75903
Car harness is painless #10201
Thanks for any help
Old Jul 3, 2006 | 07:31 PM
WILWAXU's Avatar
Let's try this one over here. Might try a post in the Conversions & Hybrids section too.
