DynoMat questions
Old Jun 21, 2006 | 07:06 PM
Cast00'T/A's Avatar
Default DynoMat questions
i was wonderin how much it would cost to mat in your whole back rear of a t/a. i have noticed some extra rattlin' in the back and wanna try and elimate it. any tips or suggestions if not hint me on some price ranges. thanks
Old Jun 22, 2006 | 07:08 AM
wickedwarlock's Avatar
do a search, there's a few posts already about it.
Old Jun 22, 2006 | 08:20 AM
ICRAZY6's Avatar
First, I would try to find the rattle. Culprit is probably the spare and jack. Then if you still want to DynoMat the trunk area you would have to decide what type to use. I believe that there is a spray then the material that you put down. I used the spray on a Bonniville a few years back. Worked good and It was about $20 for 2 cans. That covered the whole trunk area and worked good enough for 2 15" Kickers. Hope this bit helps.
Kenny
Old Jun 22, 2006 | 11:32 AM
CamaroSS615's Avatar
Around $40.00- $50.00 for just the back half of the car. Here is a link from E-Bay(http://cgi.ebay.com/10455-DYNAMAT-Xt...QcmdZViewItem). You get the bulk pack which will do the majority of the car for $ 82.99. That is a hell of a deal for this pack considering it retails for over $150.00 anywhere elese. In the bulk pack you get 36 sq. feet, so Im guessing 18 sq. would be more than enough to get the job done. Dynamat now sells liscense plate matting, and we all know how bad a liscense plate will rattle.
Old Jun 22, 2006 | 11:57 AM
01WS6/tamu's Avatar
Save the money and go to lowes in the roofing section and get roof and gutter flashing sealer in the rolls. It is 13.00for 25 feet and I have used two layers in every vehicle I have owned for the last 8 years. It's way cheaper and does the same thing. It comes in a roll thats six inches wide. But it does not say dynamat once it's covered up though nobody but you knows the difference.
Old Jun 22, 2006 | 07:31 PM
UnrthdxDream's Avatar
hahah is that the stuff that stinks like no other??^^
