dei 530t
Old Jun 24, 2006 | 11:29 PM
Bardelss's Avatar
Default dei 530t
I already installed the 530 and have both windows on auto up and down with the ingnition on. And down with with the second press of the unlock on the keys. My question is how do I get the windows to go up with the lock button.
Old Jun 25, 2006 | 09:31 AM
WhiteBird00's Avatar
Ungrounded Moderator
There is no way to use a second press of the lock button as another channel like you can with the unlock button. However, if you merely want the windows to go up every time you lock the car and if the 530 has a wire that accepts a momentary pulse to trigger making the windows go up then you can just connect that wire to the red with black wire at the BCM (the "lock all" signal wire).
Old Jun 25, 2006 | 05:16 PM
Bardelss's Avatar
Thank you thats what I was looking for Ill just run a by pass inside the car if any problems come up
