good place to ground the headunit?
Old Jun 25, 2006 | 07:05 PM
anasazi's Avatar
Default good place to ground the headunit?
i've installed an alpine headunit and in trying to track down a slight hiss i decided to make my own ground rather than use the stock wire harness, so i grounded it to the chassis over by the drivers left foot behind that kick panel, it was the only clear ground i knew of.
well i put it all back together and now not only is there a slight hiss but there are slight popping noises every once and awhile.
so i guess i get to do the whole grounding thing again ... i assume i should ground it to the chassis closer to the headunit using a shorter and maybe a thicker wire, right?
where should i ground it to closer to the headunit? are there any good spots right there?
Old Jun 25, 2006 | 07:07 PM
Duffster's Avatar
You could run a wire down towards the transmission tunnel and theres a few spots on there in the center to ground it. Just get a 3/4" self tapping and make sure you get good connections. This way, it's out of the way, easy to access and works!
Duff
Old Jun 26, 2006 | 12:22 PM
CamaroSS615's Avatar
Any where that is bare metal, mine was under the driver seat, I had to cut a small hole in the carpet and grounded it to the metal on the floor board.
Old Jun 26, 2006 | 12:34 PM
jimmy 2 Times's Avatar
i am using the stock ground, and i have no ground issues
Old Jun 26, 2006 | 12:41 PM
Phoenix 5.7's Avatar
i grounded mine on the trans tunnel, using one of the bolts for the shifter stuff, no problems at all. bare metal is what is most important
Old Jun 26, 2006 | 12:45 PM
GPz1100's Avatar
All stock wiring for the HU here with no noise at all. This hiss is present when the engine is running right? Or is it present at all times...
