cyberdyne gauge problem?
Old Jun 30, 2006 | 07:18 PM
px33transam's Avatar
Default cyberdyne gauge problem?
I installed a cyberdyne digital water temp gauge in my car and I was wondering if anyone had the same problem as me. I installed the sending unit in place of the plug that is in the bottom of the block behind the starter and everything worked well for about a year or so then I noticed the other day it seemed like it just lost signal or something and the numbers just started counting down until it read LO then after awhile it just started counting back up to a normal reading. I was thinking maybe it was a bad ground or a bad sending unit but do you guys think either of those problems would come and go like that or just not work at all? I figured I would see if anyone had a similar problem before I called cyberdyne about the problem.
Old Jul 2, 2006 | 01:07 AM
87ls1rx7's Avatar
I have had my hooked up for a bout a week, and i cant get mine to read anything but Lo, so i dont know what to do, and i have the oil pressure and fuel and they all just say lo
Old Jul 2, 2006 | 12:46 PM
I also have a trans temp hooked up that works well but the water temp just comes and goes. Like I said though it worked good for about a year then just recently it started acting up.
Old Jul 11, 2006 | 08:42 PM
anyone else have problems with temp gauge??
