here's my new sub and amp selection
Old Jul 2, 2006 | 08:12 PM
badmfkr's Avatar
Default here's my new sub and amp selection
amp it has the bass *** I like. the HU & speakers are still oem
http://www.pioneerelectronics.com/pn...869076,00.html
http://www.onlinecarstereo.com/CarAu...roductID=14539
thinking of forgetting about the infinidys and going / these
http://www.onlinecarstereo.com/CarAu...roductID=14545
http://www.crutchfield.com/S-WZwh1YE...520#morephotos
confussed amp is 2 ohm sub is 4 ohm
do you guy's think this will sound like a ok home sys.?
Thanks for advice
Old Jul 2, 2006 | 08:22 PM
Josh_101's Avatar
That amp will run the sub at 250 watts RMS and 360 if the sub was 2 ohm.
Old Jul 2, 2006 | 09:02 PM
badmfkr's Avatar
Default dvc
so you are saying I would need a dual voice coil speaker (which the infinidy is not) wired it in parrell to get the most out of the amp? and if it is to loud then just turn the gain down.
I'm thinking maybe just get the amp & sub from Pioneer and be done with phase 1 of my audieo buildup.
I'm finding out not many amp cos. offer a front bass ***.
Thanks
Old Jul 2, 2006 | 09:15 PM
camscam02's Avatar
jl offers the external front bass *** for their amps! they are nice quality!
Old Jul 2, 2006 | 10:20 PM
Josh_101's Avatar
From the looks of the impendance rating, that might be a dual 2 ohm or 8 ohm. So I think the final load will be 1 ohm and 4 ohm.
This one here is nice, but it might be out of your price range.
http://www.onlinecarstereo.com/CarAu...roductID=14489
What kind of box are you going to use?
Old Jul 3, 2006 | 08:32 AM
badmfkr's Avatar
Default infinidy 10.1 has better specs than the VQ
I believe that the older model 10.1 infinidy is a better sub than the VQ
VQ Sensitivity: 87 dB 10.1 - 94dB more efficeint
RMS Power Range : 75-400 Watts 75-350rms
Peak Power Handling: 1600 Watts 1400Watts
Impedance: Dual 4 Ohm unchanged
Low Frequency response: 25 Hz 18Hz better for low notes
High Frequency Response: 400 Hz 200Hz
box is a homemade fiberglass stealth sub thump .6 cubic inch.
this is another reason I like the 10.1 works well in a small box.
http://www.cardomain.com/ride/685057/6
I'll check into JL amps/ bass **** I have also been told that a **** can be added to any amp.
Thanks
Old Jul 3, 2006 | 12:11 PM
TA guy's Avatar
You will have about the same frequency responce and loudness with either driver, while the VQ (with the low Q insert) holds a very very slight advantage in frequency responce, it is nothing substantial, approximately 1db louder at 20hz with 250 watts.
You do highlight why I don't like infinity though, their specs are misleading. The sensitivity of both drivers is roughly the same. The spec on the VQ is an honnest industry standard spec while the 10.1 is the in car number, the same applies to the "low frequency responce" spec. Both drivers will preform almost identically in loudness and frequency responce in your box, buy which ever is cheaper if you must buy infinity.
Old Jul 3, 2006 | 12:24 PM
TA guy's Avatar
Also, The remote bass control on the pioneer is a bass boost, not a gain, so it is no different than what you already have. If your goal is removing the typical car audio boominess, this is not going to help you.
Old Jul 3, 2006 | 12:36 PM
TA guy's Avatar
Upgrading your amp from a 250w to a 360 is only going to gain you about 1.5db to 2db in additional output, while it would make your new sub as loud or louder than your RF at all frequencies it is a very minor upgrade at best. If you are looking for a noticably louder setup you may want to consider a 12" (or larger) sub, multiple subs, a ported enclosure, more power and a sub that can take it, or all of the above.
Old Jul 3, 2006 | 02:35 PM
WantedRawb's Avatar
i would personally pass all that equipment up for nicer cheaper equipment check out caraudio dot com.....
Old Jul 4, 2006 | 07:12 AM
badmfkr's Avatar
Default LTs in Cali
looks like you have the right mods waiting this stuff really improves the power.
so as long as you have cats you can pass emisions I've heard Cali is strick on this issuse and there can be a substanal fine.
