Power Antenna Motor
Old Jul 3, 2006 | 10:40 PM
BoneSS's Avatar
Default Power Antenna Motor
Putting one on my Camaro. I know there are three wires--1 orange (power), 1 black (ground), and one green. What is the green wire? From my HU I have a power antenna wire, but am confused on what the green wire does and if I need to hook it up, and if so, where? Thanks
Old Jul 3, 2006 | 11:08 PM
VIP1's Avatar
Copy & Paste Moderator
http://www.blackcamaro.com/antenna.htm
Old Jul 3, 2006 | 11:31 PM
BoneSS's Avatar
Thanks! I've read that, and it seems the green wire is just a remote lead kind of like what you hook up to an amp--is that right? I could just splice it into the wire I use for that part of my amp setup then?
Old Jul 4, 2006 | 08:40 AM
WhiteBird00's Avatar
Ungrounded Moderator
The green wire is a low current "trigger" to signal the antenna when to raise or lower. It should be connected to the power antenna wire from your head unit. The orange wire is battery power that actually powers the antenna motor. This way the antenna will stay up while the retained accessory power is active but still have battery power to lower when you exit the car.
Old Jul 4, 2006 | 02:37 PM
BoneSS's Avatar
Thanks alot!
