power window harness question
Old Jul 8, 2006 | 08:04 PM
408Maro's Avatar
Default power window harness question
my 02 z28 currently has manuel windows and door locks and all that if i got the whole door off a 98 z28 is there a harness some where in there or what can i do?
Old Jul 9, 2006 | 01:12 PM
WhiteBird00's Avatar
Ungrounded Moderator
There's a lot more involved than just the parts in the door. Yes, you'll need the door parts (harness, switches, window motor, lock solenoid) but you also need a different BCM containing the keyless entry option, a window control module that mounts under the dash, and the wiring for them.
Old Jul 10, 2006 | 08:44 PM
408Maro's Avatar
wheres the window control module at? the bcm seems easy how bout that though
Old Jul 11, 2006 | 07:01 AM
The power window module is a small black box mounted in a pocket attached to the dash mat under the dash behind the center console close to the transmission tunnel.
Old Jul 11, 2006 | 09:25 AM
408Maro's Avatar
thanks alot i appreciate it
