Help with factory cdplayer!!!
Old Jul 16, 2006 | 11:31 PM
StatixNWH's Avatar
Default Help with factory cdplayer!!!
Hey guys....just a quick question....my cd player screen when i first start it up is all jumbled...it takes a while then it acts right....I noticed at night when it dims, sometimes it gets even dimmer, like it wants to go out.....well tonight it did....the screen goes blank....if i hit around it it flickers back on but goes back off after a few seconds.....what could this be?
Old Jul 17, 2006 | 08:16 AM
todddchi's Avatar
It is a common problem with the monsoon head units - it is due to bad connections in the display. I'm 99% sure if you search here and google you will find some images and walkthroughs of the problems.
If you are handy with electronics and soldering, you can fix it. A knowledgeable repair shop will also know what to do. Otherwise it is time for an upgrade or to find a used unit.
Old Jul 17, 2006 | 04:03 PM
VIP1's Avatar
Copy & Paste Moderator
https://ls1tech.com/forums/showthrea...onsoon+display
https://ls1tech.com/forums/showthrea...ht=monsoon+led
