Newb Amp question
Old Jul 21, 2006 | 03:44 AM
Bluehawk27's Avatar
Default Newb Amp question
Will the kickerZX750.1 Amp work well with 2 CompVR 12" @ 4 ohm? If so how should i wire them to get the most out of the set up? This is on a stock monsoon stereo with the subthump t-top well box.
Thanks guys
Old Jul 21, 2006 | 01:33 PM
todddchi's Avatar
With that amp you'll want your subs wired up to present the amp with a 2 ohm load.
If both of your subs are single coil 4 ohm subs just wire them in parrallel and you are all set. It won't hurt the amp to show it a 4 ohm load but you'll be screwing yourself out of half of what the amp can provide.
This will also heavily over power a factory monsoon system. You'll be all bass.
