Quick question about sub..
Old Jul 21, 2006 | 07:39 PM
02trns_am's Avatar
Default Quick question about sub..
I am about to order a 10" Rockford Fosgate stage 3 for the subthump stealth box and I was needing to know the difference in the dual 4 ohm and the 2 ohm. I haven't got an amp so i donno....Just an audio newb looking for advice thanks everyone.
Old Jul 21, 2006 | 08:09 PM
Blacker's Avatar
The dual 4 ohm sub has two 4 ohm voicecoils that can be wired for series (8 ohm) or parallel (2 ohm). The dual 2 ohm sub has two 2 ohm voicecoils that can be wired for series (4 ohm) or parallel (1 ohm). Basically, if gives you flexability in your design. For instance: I have a 600Wx1 @ 2 ohm Ampilifier pushing 2 Alpine dual 2 ohm 10" subs. That gives me a final load of 2 ohm and that is where the amp makes the most power. If you were using one 10" sub, get the dual 4 ohm and wire it in parallel.
Old Jul 23, 2006 | 02:00 PM
02trns_am's Avatar
Hey blacker, Thanks for the info...I got the 4 ohm...I got a Phoenix gold x400.1 I think thats wat its called.
