remotes
Old May 23, 2002 | 03:22 PM
Z-Rated's Avatar
Default Re: remotes
Try this if there from a stock alarm. Put the key in the ignition, turn it to run then to off. This turns off your alarm. take out the "radio" fuse, open your driver side door to find that. Turn the ignition from off to run three times (within 5 seconds) then the car will lock the doors, unlocking the drivers door and releasing the hatch. Leave the key at run. press and hold the unlock and lock buttons for about 15 seconds. The car will again lock, unlock then open the hatch. Once your done replace the "radio" fuse. hope this helped
Drew
Old May 23, 2002 | 04:28 PM
Air21's Avatar
Default Re: remotes
its a little extensive to program a remote but i'll try it. This works for all models including the 95?
Old May 23, 2002 | 04:56 PM
Z-Rated's Avatar
Default Re: remotes
I honestly dont know about the 95 alarm, its realy not that long or hard at all. My friend had to do it one his truck. Good luck.
Drew
Old May 24, 2002 | 12:45 AM
Air21's Avatar
Default remotes
i have two extra remotes that i found in my garage. Is there anyway i can calibrate them to work on either of my cars?
I have a 2001 and 2002 T/A as well as a 95z
