sub speaker help
Old May 28, 2002 | 08:56 PM
stevenb8's Avatar
Default sub speaker help
Im a new member and trying to find out if there is really no speakers that we can put into the TA monsoon system as a direct replacement. Im getting yes and no from several sources.
I need some experts on what to do or part #'s to replace the 6.5 subs with.
thanks
Old May 28, 2002 | 09:27 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: sub speaker help
I haven't found any good replacements either. Our Pontiacs have dual voice coil subs in that location, each coil is 4 ohm. Running in a parallel wiring configuration, the amp is working at 2 ohms per speaker.
So, if we stick something in there with a higher ohm rating, we actually get less sound since the amp will just be working under more load.
The best option is looking like installing some 6-8" subs in there and running a seperate amp just for those.
I'm still looking for some unblown stock speakers for that location.
Tony
