crossovers
Old Jul 18, 2002 | 04:20 PM
dutch 99 chevy's Avatar
Default crossovers
i need to get one(maby more i dont know). i have three different amps, 1 for my 4 mids and 2 tweeters, and one for each sub. can i get one cross over or do i need more, any input is great. also where can i get them and how much.
thanks
zach
Old Jul 18, 2002 | 06:38 PM
LIL SS's Avatar
Moderator
Default Re: crossovers
How are are you running your sub amps? Are you using the output of one amp to feed the other? If so you should be able to get away with 1 cross over that has 6 out puts.. Front,rear and subs..
Old Jul 18, 2002 | 08:53 PM
yeah, my rca's run from one amp to the other, but the subs rca go into my main 4ch. amp that pushes my mids and highs.
Old Jul 18, 2002 | 08:55 PM
dsedlund's Avatar
The "Audio Control - EQX" is an incredible crossover that would solve your problem. Check it out HERE
The crossover has single preamp input and full, high and low outputs.
Good Luck
Doug
