Help Me, Please!!!!!
Old Jul 30, 2002 | 02:47 AM
Pewter'00Z28's Avatar
Default Help Me, Please!!!!!
I hope I found the right section. I'm trying to figure out a way to convert a fog light switch out of a 2000 Z, to be my nitrous active button. The reason I posted here is because the back of the switch has 5 prongs and I just need to know which is ground and which is power, if I can get the light to work too that would be way cool, I have in place of where my camaro badge used to be, if anyone can help it would be greatly helpful. Thanks.
Old Jul 30, 2002 | 09:13 AM
Xsta Z 28's Avatar
Default Re: Help Me, Please!!!!!
Going to move to "Electronics" hopefully get your answer there.
Andy
Old Jul 31, 2002 | 12:25 AM
ttt
Old Jul 31, 2002 | 02:04 PM
LIL SS's Avatar
Moderator
I have not checked this out before but here are a couple helpful hints. If you look at your existing connector for the fog lights it might gise some indacation to what ones are the leads your looking for.
Another Idea would be to take a meter and disconnect the switch from the harness and see which one is power. Then after that you could probably find the ground by pluging back in the switch and test of the back side of the connector with that same meter. Don't know if that helps any..
