the factory monsoon subs keep blowing
Old Aug 18, 2002 | 08:53 PM
chris's ws6's Avatar
Default the factory monsoon subs keep blowing
The speakers that are located where the passengers in the back seats ears would be, keep on blowing. The ones that only produce bass. I was wondering if I could just replace them with a JL Audio free air 8 inch sub on each side( will they be able to be a direct replacement for the factory speakers), or if I should add a box and amp in the trunk. If I did add a box in the trunk I would want one that does not block the storage area for the t-tops, should I have a custom enclosure made that will fit on the back rack behinde the rear seat under the glass hatch or do you guys recommend a mass produced box like one from q-logic. I have heard that the q-logic boxes are not the best in terms of quality. What do you guys think I should do? Any info would be greatly appreciated.
Old Aug 18, 2002 | 09:43 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: the factory monsoon subs keep blowing
Nobody makes a direct replacement for those subs, since they are 6.75" dual-voice coil subs. They are also 2 ohm when both voice coils are in parallel wiring (dual 4 ohm coils).
I blew mine also, and haven't found anything useful to put in there.
I'd highly recommend an RS-series 8" Bazooka tube. I bought one for my GMC and it sounds great, it actually hits pretty hard for a little 8" woofer. It was simple to hook up, easily removable, and only weighs 20 lbs total with its built-in 150W amplifier. I paid $219 from www.NowOnSpecial.com and received it in less than a week.
Tony
Old Aug 18, 2002 | 10:30 PM
RTCamaroSS's Avatar
Mine blew as well, but i have 2 10 inch MTX subs in the rear so im not worried about bass. What i did, was replace those 6 3/4's with infinity kappa 6 3/4's, the woofer is wired up like normal to that channel, but i ran some wires to the rear speakers to get a tap on the tweeters. Yeah yeah, you all will probably say that i reduced the ohm rating.. but who cares, it sounds awesome. Now that there are highs coming from all over the car, it gives a total sound. Its awesome. Heres my setup.. Far Rear: Infinity Kappa 5x7's Center: Infinity Kappa 6 3/4's Front Door: Infinity Kappa 6 3/4's... Two MTX 10" Subs in the rear. Factory monsoon deck and amp... sounds absolutely awesome.
Old Aug 19, 2002 | 09:43 AM
GREEN GOBLIN's Avatar
I replaced mine w/ MA Audio 6.5" subs and I've had no problems at all. Overall, a great bass increase! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I'm happy! <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
Old Aug 19, 2002 | 11:18 PM
I have never heard of MA Audio. Where can I order their speakers from or who carries them, how much were they, and is there any particular way that I need to wire them?
