How do i run wires from a-pillar to the engine compartment?
Old Aug 20, 2002 | 08:02 PM
TomQ's Avatar
Default How do i run wires from a-pillar to the engine compartment?
I need to run wires(temerature sensor) from my rear view mirror to somwhere between radiator and front bumper
Teh wires go from mirror to the a-pillar and then they should go somewhere to the engne compartment and so on <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
How do i run wires
Old Aug 21, 2002 | 01:13 PM
TomQ's Avatar
Default Re: How do i run wires from a-pillar to the engine compartment?
oh my god, nobody has never done it ?!
Old Aug 21, 2002 | 03:17 PM
TanRchy's Avatar
When i wired my tach in, I ran a the wires to the fuse box as u open the driver door. maybe think about that? another option is to take off the a-pillar and the other plastic thing at the bottom door and then run the wires in it and tape it to the side "where the clutch would be" and drill a hole through the firewall. then run wires through it. I drilled a hole, not a problem but then decided to use the fuse box instead. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Aug 21, 2002 | 04:32 PM
TomQ's Avatar
right on !
i'll try to see what i can do about the fuse box and if it wont do it, i guess i will have to make a hole
