TCS and ABS buttons in the dash questions...
Old Aug 25, 2002 | 03:28 PM
Biochem's Avatar
Default TCS and ABS buttons in the dash questions...
So, I didn't go for the TCS or the ABS control options... but pulling apart my dash (poped that front cover off) I see that there are a few wires that go to a harness that sit behind those two dummy covers right above the radio. Can I just buy the buttons from GM and suddenly have TCS?
Old Aug 26, 2002 | 01:56 PM
cryptopsy's Avatar
Default Re: TCS and ABS buttons in the dash questions...
no your rear has to be equipped with it I believe...it's not that they install it on there and just don't have the switch because you don't want it...
Old Aug 28, 2002 | 11:52 AM
slow's Avatar
you need a different rear end, as well as the TCS controller box that the throttle cables to go, and it sends one cable to the TB, where if you dont have it, your throttle cable goes to the TB directly, i believe.
I know mine has it. so im going off of memory from car shows about the non tcs cars.
Ryan.
