shielded RCA cables & #5power wire ?
Old Aug 19, 2006 | 12:37 PM
badmfkr's Avatar
Default shielded RCA cables & #5power wire ?
I have the new concepts shielded RCA cables run down the right side of pass. door back to spare tire area.
I also have the #5Power wire coming from battery in same spot will these really nice shielded RCA cables need to be farrer apart from power wire?
I haven't really heard nosie being created but is this OK to have both power & RCAs together like this.
Thanks
Old Aug 19, 2006 | 05:00 PM
dan23467's Avatar
good rcas help vs. the problem that you get if you run them both by each other.. which is a slight whine or kinda buzzing or hisssing sound if there is interferance.. so if you dont notice it then there should be no problem
