Can a wire run directly from the batt. to the head unit?
Old Oct 2, 2002 | 07:30 PM
Quickin's Avatar
Default Can a wire run directly from the batt. to the head unit?
A wire with a fuse to power the head unit.
OR
Can another accessory type power supply be run from somewhere to power the head unit, but still deliver power when the car is turned off? So it will turn off with the key and turn back on with the key and still have power for the clock when off.
long story why.
Old Oct 2, 2002 | 09:18 PM
tidemandave's Avatar
Default Re: Can a wire run directly from the batt. to the head unit?
You can jump it from any accessory. Id go with the power windows. Make sure you ground it well or your going to get crazy engine feedback.
Old Oct 2, 2002 | 09:22 PM
Running straight off the battery will work too. Would be easier to run it from the fuse panel though. I'd use something that turned of with the key and on in accessory mode.
Old Oct 2, 2002 | 09:31 PM
Quickin's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by tidemandave:
<strong>You can jump it from any accessory. Id go with the power windows. Make sure you ground it well or your going to get crazy engine feedback.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">But if I run it off an acc, won't the clock lose power when the car is turned off? Or is there another power wire that always gives it power?
