adding an amp to factory h/u?
Old Oct 23, 2002 | 03:28 PM
ws6-speed's Avatar
Default adding an amp to factory h/u?
How can I add an amp to the stock monsoon h/u in my 02ws6?
I know that this can be done by using a pac module, but those things are pricey. I might as well buy a new h/u for the cost of the pac.
I seem to recall someone talking about splicing into the factory wiring and using a line-level converter. I also remember someone saying something about using two factory wiring harness. Anybody have any suggestions?
Thanks,
russ
<small>[ October 23, 2002, 03:29 PM: Message edited by: 77-vette ]</small>
Old Oct 23, 2002 | 04:18 PM
Most wanted's Avatar
Default Re: adding an amp to factory h/u?
Hmmmm the pac module isnt that pricey.
the module you need is the Pac Oem1 GM21c
Crutchfield.com has them.
for splicing and adding a LOC You need a good 1 or youll get noise in your system.
<small>[ October 23, 2002, 04:19 PM: Message edited by: GMNightmare ]</small>
Old Oct 23, 2002 | 05:20 PM
ws6-speed's Avatar
The price I saw was $80 for the oem-1 and the two other adapter's needed to connect an external amp. That is pricey! $80 is a good way towards an mp3 head unit.
Crutchfield only seems to sell the oem-2. I'm not familiar with how this connects.
If I do get the pac LOC what wires would I tap into. I'm assuming I'd just splice into the rear speaker wires (at the radio of course). I would still retain the funcionality of the rear speakers, but I'd also have a set of rca outputs for my amp. Sound right?
-Russ
<small>[ October 23, 2002, 05:26 PM: Message edited by: 77-vette ]</small>
Old Oct 23, 2002 | 05:32 PM
yes.
Let me ask My distributor tomm and see how much the kit is. they closed at 5Cst so ill post tomm.
Old Oct 23, 2002 | 05:40 PM
ws6-speed's Avatar
Thanks alot GMnightmare! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
-Actually, I just looked at my amp and it has a built in LOC. I guess I'll just splice into the rear speaker wiring at the rear speakers and run it to the amp. I'll give it a try and if it doesn't work than it's the pac system.
Thanks again,
Russ
Old Oct 24, 2002 | 09:19 AM
ws6-speed's Avatar
Ok,
So it turns out the poweracoustik LOC is crap! I would definitely appreciate it if you could get a price for me GMNightmare <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" /> Looks like I'll be adding a GOOD LOC right behind the radio.
Do you happen to know which wires to tap into for the rear output?
Thanks,
Russ
