Factory alarm brain location?
Old Aug 21, 2006 | 07:42 PM
SMOKINV8's Avatar
Default Factory alarm brain location?
Short background on the situation:
My O2 sensors started going crazy out of the blue and my factory alarm somehow re-enabled itself*, so I'm pretty sure I've got a bad ground somewhere. I'd like to know the location of the factory alarm so I can start tracing down the circuit to find my issue. I know the shock sensor is on the passenger side fender well in the hatch, but I need to know where the brain itself is.
Thanks in advance.
* The alarm goes off if I lock the doors by the remote, and if I lock the doors by the electric lock button it goes off when I shut the door.
Old Aug 21, 2006 | 08:00 PM
MikeFbody's Avatar
Restricted User
there is no separate alarm brain, it's part of the BCM. BCM is on the passenger side dash, behind the glove box, under the airbag, all the way to the right.
Old Aug 22, 2006 | 06:27 PM
SMOKINV8's Avatar
Thanks Mike, that helped me get to the next step in my miniature mess.
Next question, which wire from the BCM goes to the Gauge fuse in the fuse panel? The owners manual shows that the "Gauges" fuse has the BCM on it, but the other BCM features seem to function just fine. So is it safe to assume the power for that fuse's power comes FROM the BCM? I've got the pin-out for the BCM, but I don't see anything that looks like it goes there.
Main (Blue) Connector:
C1
BLK
650
Ground
C2
PPL/WHT
1074
Ignition key resistor return
C3
Not used
C4
PPL/WHT
237
Fasten seat belt indicator control
C5
DK GRN
220
Starter enable (V6 VIN K)
C6
DK GRN/WHT
817
Vehicle speed input (Gulf States)
C7
GRY
157
Interior lamps command input
C8
BLU/WHT
624
Park lamps relay control (Domestic)
C8
YEL
1977
Rear fog lamp relay control (Europe)
C9
BLK
BLK
Horn relay control
C10
Not used
C11
YEL/BLK
625
Starter relay control
C12
GRY
728
Security indicator lamp control
C13
BLK/WHT
238
Seat belt switch signal
C14
LT GRN
80
Ignition key signal
C15
YEL/BLK
68
Low coolant indicator latching
C16
Not used
D1
WHT
156
Courtesy lamps return
D2
LT BLU
263
Shock sensor tamper input
D3
BLK/WHT
1576
Rear compartment lid release signal
D4
BRN
253
Rear compartment lid release relay control
D5
PNK
39
Ignition positive voltage
D6
YEL
49
Program input
D7
WHT/BLK
1037
Ignition key resistor feed
D8
DK BLU
229
Fuel enable
D9
LT BLU
187
Rear fog lamp request (Europe)
D10
Not used
D11
GRY/BLK
745
Driver door open input
D12
BLK/WHT
746
Passenger door input
D13
ORN/BLK
737
Rear compartment lid ajar input
D14
LT GRN
1828
Shock sensor shock input (Domestic)
D14
BLK
650
Ground (Europe)
D15
BRN
9
Park lamps feed
D16
Not used
