Amp Install Question?
Old Oct 30, 2002 | 01:31 PM
SuperSound99SS's Avatar
Default Re: Amp Install Question?
If it will work which im not totally sure that it will..this link is what you need
monsoon wiring
Old Oct 30, 2002 | 02:34 PM
02Z's Avatar
02Z
Thanks! SuperSound, I really needed that wiring Data. <img border="0" alt="[hail]" title="" src="graemlins/gr_hail.gif" />
I don’t want to use a line inverter if the amp has one built-in. I figure less noise with the Amp inverter; it should be integrated into the front end of the amp... Don't you think?
Old Oct 31, 2002 | 12:57 AM
02Z's Avatar
02Z
Default Amp Install Question?
I am installing a sub with and a MTX amp on a Monsoon System. The Amp has the high level inputs. Can I take the inputs going into the Monsoon amp and run them to the MTX amp? If so, does anyone know the Monsoon speaker input wire colors? Any help would be appreciated… <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
