Speaker swap help!
Old Nov 12, 2002 | 11:49 PM
glitch77's Avatar
Default Speaker swap help!
<img border="0" alt="[kaboom]" title="" src="graemlins/gr_bomb.gif" />
Well, Ive done it this time. I got 4 Pioneer TS-A1767 6 3/4" speakers to swap with the factory ones. And problem is, the front two speakers (in the doors) are dual voice coiled. Is there any way in Gods name I can hook them up and not have a seperate tweeter?
I *think* there is a +/- set of wires for the tweeter that has 100% treble, and another set that has 100% bass. And I cant cut the highs to the front set and just have bass, cuz that would leave only the back two 4"ers making treble. And I cant kill the bass because they really pound for such a lil' speaker. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ November 12, 2002, 11:50 PM: Message edited by: glitch77 ]</small>
Old Nov 13, 2002 | 08:21 AM
ws6-speed's Avatar
Default Re: Speaker swap help!
Give me some details about the Pioneers (can't look up the detail here at work).
Old Nov 13, 2002 | 08:35 AM
glitch77's Avatar
6.75" 3-Way Speaker 220 Watts Max. Power (50 Watts Nominal)
<img src="http://www.pioneerelectronics.com/Pioneer/Images/CarProduct2002/TS-A1767.jpg" alt=" - " />
Features
Foamed IMPP (Injection Molded Polypropylene) Rigilite™ Composite Cone Woofer
High Energy Strontium Magnet (Woofer and Midrange)
Butyl Rubber Surround
Latex Treated Conex Damper
Glass-Imide Voice Coil Bobbin
CCAW (Copper-Clad Aluminum Wire) Long Voice Coil
1-3/8" Foamed PPC (Pearl Polycarbon) Balanced Dome Midrange with Magnetic Fluid
3/8" Dome Tweeter
Full Depth Basket
Custom Fit for Oversized 6-1/2" Applications
Chrysler 3-Hole Adapter Included
Specifications
Mounting Depth: 2-1/2"
Tweeter Protrusion: 1/2"
Sensitivity (Efficiency): 91dB (1W/1m)
Frequency Response: 28 - 30,000Hz
Cutout Dimensions: 5-5/8"
Impedance: 4 ohms
Old Nov 13, 2002 | 01:05 PM
ws6-speed's Avatar
Nope,
you're not going to have much luck. The amp has the crossovers built in, so the wires running to the tweets have only highs and the wires running to the midbass have only lows. I don't think that there's a downconverter that can mix highs and lows into a single output. Sorry.
Hopefully someone else can chime in.
Russ
Old Nov 13, 2002 | 01:25 PM
SuperSound99SS's Avatar
here's what i would do man....take ur pioneers and put them in the sail panels slots(since the sail panel speakers are used only as "subs")unplug the back 4" speakers(since they are 4ohm) and use their wires to power ur pioneers...now u'll have 2 pairs of full range speakers= much better sound....if u have any ?s email me
Old Nov 13, 2002 | 04:18 PM
glitch77's Avatar
I am going to step into the world of the unknown.... Im gonna dicect my Pioneers and seperate the whoofer from the mid/tweet assembly. I will then try to inject the highs into the assy. and the lows into the woofer. This should be fun. <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
