Amp Question
Old Nov 13, 2002 | 06:21 AM
Rok's Avatar
Rok
Default Amp Question
I recently installed a new amp and 12" sub, my problem is that my amp keeps shuting off and if I shut off the car open the door so the radio shuts off the amp comes back on.
Now the amp has a lot of open space so it shouldn't be overheating.
What do you think the problem is?
tia
rok
Old Nov 13, 2002 | 08:27 AM
ws6-speed's Avatar
Default Re: Amp Question
Sounds like you have the amps remote turn-turn on wired to the incorrect source. If you have a firebird, you can tie into the pink antenna wire. Nor sure about the camaro's. You could always tap into an ignition source (pink wire in the ignition harness I believe).
Russ
Old Nov 13, 2002 | 01:27 PM
SuperSound99SS's Avatar
yea that sounds like the problem...i believe not sure though that the camaro wire is pink too
Old Nov 14, 2002 | 05:54 AM
Rok's Avatar
Rok
thanks for the reply guys
so the remote wire has to be hot all the time?
I didn't do the install I had it installed at Circut City. But I will check it out.
thanks
rok
Old Nov 15, 2002 | 07:28 AM
ws6-speed's Avatar
Circuit city does horrible installs (in general).
But NO, THE REMOTE DOES NOT GET A CONSTANT 12V.
The remote turn on wire should be connected to a wire that shows +12V when the key is in the run, on, or accessory position, and 0V when the key is in the off position.
Russ
