the right way to wire it??
Old Jan 14, 2003 | 07:53 PM
rbrooks's Avatar
Default the right way to wire it??
i have just finished installing one 10"sub and an amp. my question is about my my wiring. i wired the sub into my right rear speaker. can anything go wrong by doing this or will it work ok? my car came with the monsoon system and i heard it might mess something up. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> need some help guys!
Old Jan 14, 2003 | 09:05 PM
Beeler422's Avatar
Back in the staging lane
Default Re: the right way to wire it??
If you wired it in using a PAC modulator or something of the sort, it will be fine as long as you wired it correctly.
Old Jan 14, 2003 | 11:15 PM
exSStacy's Avatar
Well that depends on if that rear speaker is one of the stock mids or bass speakers. In my SS the bass speakers are next to the beck seats and I have 4" mids further back. If yours is the same and you wired it to the mid that is further back that speaker is crossed over and you might not be getting all of the frequencies that you want to your amp.
Old Jan 15, 2003 | 01:18 PM
Beeler422's Avatar
I'm pretty sure on the TA's there are 2 speakers in each rear panel whereas in the SS's there is only one. Not sure if it makes a difference as I just ripped my stock system out without studying it <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> but I had mine wired the same way for a couple weeks and it was fine.
