Need help..wiring diagram
Old Mar 5, 2003 | 07:09 AM
LS69TA's Avatar
Default Need help..wiring diagram
I need to find a wiring diagram for my '02 camaro. I'm going to have my new alarm/remote start installed and my buddy wants a diagram to make chasing down wires easier. Thanks..
Old Mar 5, 2003 | 09:43 AM
slow's Avatar
Default Re: Need help..wiring diagram
12volts red + ignition harness
Starter yellow + ignition harness
Ignition pink + ignition harness
Power Lock red/black - green plug at the BCM
Power Unlock tan & gray/black 5wi green plug at the BCM
Lock Motor gray green plug at the BCM
Unlock Motor tan green plug at the BCM
Disarm Defeat gray/black green plug at the BCM
Parking Lights+ brown blue plug at the BCM
Parking Lights- black/white blue plug at the BCM
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger - blue plug at the BCM
Dome Supervision none
Trunk/Hatch Pin orange/black - blue plug at the BCM
Hood Pin none
Trunk/Hatch Release brown + blue plug at the BCM
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock none
Tachometer white blue plug at the PCM
Horn Trigger black - blue plug at the BCM
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer By Pass : Not Available
MAKE : CHEVROLET | MODEL : CAMARO | YEAR : 2002
Hope this helps, its DEI's info
Old Mar 5, 2003 | 10:05 AM
LS69TA's Avatar
Thanks, i was trying to find that DEI info.
