PAC SWI-X install locations
i work in a very dirty factory and it's ******* up my car
p.s. i took these tonight after work and i can assure you the car has never looked this bad before. the flash makes it look worse
Yep, that where i place my IR transmitter. Its a nice spot to install it. The only problem is that when im in 5th gear it doesnt work. The shifter blocks the signal. Every other gear is fine.
But as it is - was simple and works fine.
I do recommend you glue the emitter into the housing, and put a little glue on the housing to your console (backside). People who rest their arm there will push the emitter back down through if you don't glue it, pita.
Now it is time Jim to post up the 'Clean Car'
EDIT: now we have to clean that carpet.. but lets get the cavalier back together.. Where you work with all the oil, that carpet will never be clean.
