Error message with CD changer
Old Mar 25, 2003 | 01:39 AM
01 Sunset Orange TA's Avatar
Default Error message with CD changer
Our TA came with a trunk mounted CD changer, whenever we put a CD in and try to listen to it it comes up with E34, I know this is an error message, could it be the CD or the changer itself <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 25, 2003 | 01:46 AM
Big Ty's Avatar
Default Re: Error message with CD changer
Mine does that sometimes when its a certian brand of burned CD's.
Old Mar 25, 2003 | 11:56 AM
Its not a burned CD, guess Ill try another cd and see if it works.
Old Mar 26, 2003 | 12:02 AM
Last Yellow Bird's Avatar
When I got my T/A with Trunk mounted changer, I had the same problem. The CD's get loaded into the individual plastic trays up-side-down from what you would expect. You may have them in backwards. Try flipping them over, and see if that works. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 26, 2003 | 12:36 AM
stevews602's Avatar
E20 means the unit is dead
E35 means that the CD cartridge is empty.
E30 means that the CD label is wrong side up
E34 means that the changer door is open
E33 is a changer communications error
The changer door has two tabs on them to tell the changer when the door is open and closed. If one of them is broken off then you would get this error even it the door is shut. I had this issue and ordered a new door from Pioneer. If your car is under warrantee get it replaced.
Old Jun 24, 2006 | 12:37 PM
fosgate3's Avatar
Having an error code on my pioneer changer as well. The changer is a CDX-P2000. It's indicating an "Error 60". What does this mean?
