door speaker question
Old Sep 7, 2006 | 04:06 PM
RaNsOm's Avatar
Default door speaker question
Hey all, I ended up blowing out my passenger side door panel speaker over the weekend. I went on ebay, found 2 brand new 6" sail panel speakers and replaced those (since they were blown) now I have BASS again, and I also bought a set of door speakers. However, when I received them, they looked different. The magnet on the back is MUCH larger than the stock one, but the plug connector is only for 2 wires. My stock one is the larger, more square plug with 4 wires. Now I have my door panel apart with speakers that wont work. WTF speakers do I have? I think they are Trans Am door speakers because they do not have a tweeter in the center.
Are these the correct DOOR speakers for a CAMARO with the 500w MONSOON system?
http://cgi.ebay.com/ebaymotors/Two-2...25565688QQrdZ1
Is there an aftermarket alternative for the 2ohm system that would be less than $115?
Old Sep 7, 2006 | 04:58 PM
bjamick's Avatar
ya man those look like the right kind!! make sure there 2 ohm
Old Sep 7, 2006 | 07:01 PM
1BADLSS1's Avatar
how did you get the panel off if you dont mind me asking cause I blew the speaker myself and I wanna change em
Old Sep 8, 2006 | 04:38 PM
bjamick's Avatar
you talking bout the door panel or what???
Old Sep 8, 2006 | 09:35 PM
1BADLSS1's Avatar
Yes the door panel do I need a certain tool??? or is there a trick to getting them of with out breaking the pins, plugs what ever there called thanks
Old Sep 9, 2006 | 03:07 PM
Funkster's Avatar
5 total screws need to be taken out. Then go underneath the door panel with your hand and feel side to side until you feel a piece of plastic. Lift up on it and it will slide out, then continue doing this all the way around the door panel.
Old Sep 10, 2006 | 05:42 AM
rotwiler's Avatar
Adding Infinty kappa 62.7i's was the best thing I did when my stock speakers were bad, sound much better and 2ohm like stock, even fit perfect in the sailpanel. You must have been sent T/A speakers.
