Monsoon CD going out
Old Sep 11, 2006 | 07:48 AM
BTTM's Avatar
Default Monsoon CD going out
My monsoon stereo CD is going out. Thinking about replacing the whole system. A couple of questions as I decide which route to take from here:
1. To replace the entire system, how much can I expect to spend, minimally. I don't need a 5000 watt system, but I also don't want something cheap. I listen to mostly gospel, classical and talk radio. I already have a set of 6.5" sail panel replacements by Rockford Fosgate.
2. Can I run a system that will look stock (except the deck of course). I need my trunk space so sub enclosure in the trunk wouldn't work. I might get by with puting the amp back there, but my worry is that it will get damaged.
Old Sep 11, 2006 | 11:15 AM
BTTM's Avatar
Also, what do I need to look for in an amp?
Old Sep 11, 2006 | 03:40 PM
dragonrage's Avatar
I like Eclipse amps. They have some ICEpower full-range class D amps that I find very nice because of the efficiency (meaning lower power draw, cooler running, and usually smaller)
