Harlan shift light and unhooking battery
Old Sep 16, 2006 | 11:59 AM
Rynofasho's Avatar
Default Harlan shift light and unhooking battery
My light still lights up at start. I pulled the battery though to do something. It wont come on when it is time to shift. Does it lose its programming when you pull the power. Im gonna try to reprogram it anyways but I dont have time right now so I thought Id ask. Thanks.
Old Sep 17, 2006 | 08:29 PM
PowerShift408's Avatar
Mine did the same thing. I reprogrammed and still nothing... Help!
Old Sep 17, 2006 | 09:09 PM
HavATampa's Avatar
hmmmm...mine doesn't lose it's programming when I disconnect the battery. It's configured with jumpers and not set to memory. Tach wire to the pcm shorting out?
Old Sep 17, 2006 | 09:15 PM
Well I have only seen mine come on once ever... It was in the car when I bought it and it was set to 6600 rpm. My car is a 408 and I'm not comfortable revving it that high. So today I go to reset it, and do so at 6100 rpm. I get all the visual confirmations that I have done everything correctly, but nothing happens when I hit my shift point. I've heard that it needs to be set to 4-cyl mode as well... is this true? If so, that is my problem, as I have it in 8-cyl mode. Any help would be appreciated. I may have to check the wiring soon as well, if I can't figure anything else out.
Old Sep 17, 2006 | 11:07 PM
01 Red WS6's Avatar
I'm pretty sure it should be set to 4cyl
Old Sep 17, 2006 | 11:11 PM
Thank you 01 Red WS6... Now could someone provide me with the DIP switch 4-cyl settings. I don't have instructions or anything. I went by Install University's how-to and they set their's to 8-cyl, but they do not show the 4-cyl DIP settings. Hopefully this will cure my problem.
BTW, I think you may know the guy I bought my car from, I'm the guy that bought Brandon Bauer's car.
Old Sep 17, 2006 | 11:53 PM
SSmokin 01's Avatar
Mine has never lost its settings and I've had the battery disconnected many times.
Here's a few pics (scanners not working) of my directions that came with the light. The 4 cyl dip settings are in the 2nd to last pic.
Old Sep 18, 2006 | 01:49 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
where did everyone get this at. I am trying to find on. Prev. Blue light.
Old Sep 18, 2006 | 05:44 PM
Well I tried 4-cyl mode today and I'm still a no go... I suppose it's time to go through all the wiring.
Old Sep 18, 2006 | 07:09 PM
HavATampa's Avatar
Thumbs up
It's a Harlan Shift light. I thought he quit making them, but see his webpage still list them. http://www.harlan-engineering.com/store/store.html
That was mighty nice of you Ssmokin to take the time to post the directions. Just in case somebody needs the instructions in .pdf format, here's the link http://www.harlan-engineering.com/st...structions.pdf
Old Sep 18, 2006 | 11:14 PM
SSmokin 01's Avatar
Thanks. I try to help when I can. Your way is much easier though . I'll keep that link for future reference.
