Stock charging system limits
Old Sep 25, 2006 | 09:55 PM
rickJames's Avatar
Question Stock charging system limits
I am getting ready to install a system in my car and had a question concerning the stock charging system.
How much can the stock charging system handle?
I will be using this amp Kicker ZX700.5
I also have a underdrive pulley installed.
I thought about installing a better battery (Optima Yellow or Red top). But i am worried that the alternator will not keep the sucker charged.
Do you think I will need a upgraded alt or overdrive pulley on the stock unit? I know all cars are different just trolling for some opinions.
Cheers
Old Sep 25, 2006 | 10:36 PM
GPz1100's Avatar
Rick,
I think you'll be ok. My amp arrangement is roughly similar in terms of max rms output power (~925watts between the 2 amps). I have a stock alternator and have had no issues. No lights dimming at night either.
I would wait until you get everything installed then determine if you need to upgrade your alternator or not.
A higher capacity battery would be helpful if you like to listen to your stereo at length with the car off. With the car on, the alternator makes the difference.
Old Sep 25, 2006 | 11:07 PM
todddchi's Avatar
It'd be pretty close to the line on stock, but that underdrive pulley might kill you.
