Stereo wiring harness problems
You could either hardwire the new radio in like the old radio was.. just using the new radios plug and hard wiring to the factory wiring, not using the harness adaptor you baught. also you could buy the gm 1988 and up reverse harness, which would be the same as the factory plug, and put it back in. then youde use the harness adaptor you baught to plug into that and then connect to wires from the radios harness.
The power antenna should be in that harness, although the steering wheel controlls wont be, those would need an adaptor like the pac swi-x unless you already have it. If you are going to use that adaptor the radio you are putting in needs to support a remote
