Double Din DVD units
First off, don't be afraid of cutting out a decent amount of plastic from your car. Be prepared to make your on mount. Know how to cut plastic very smoothly, or make a new trim ring. Be prepared for a tight fit, and have very low profile right angle signal wires.
Hey , your TA is sweet .
The headunit was a bit of a pita , but yeah , hehehe , it WILL fit just fine . The head unit I used even allowed me to use the radio controls once I figured the right wire to hook up . I was amazed . To make the radio fit I didnt have to relo the hvac unit at all . I just had to cut out that center shelf divider and basically build a new one that sat lower ....basically almost touching the hvac unit . I used sheet ABS plastic and fiberglass resin to make a new shelf . I also had to make new side mounting brackets to line up with the old radio mounting holes . After that , the head unit bolts right in like stock . The actual bezel itself that surrounds the radio and hvac , I did have to rebuild to make the radio opening bigger . In the middle divider I left the portion that surrounds the Hvac alone , and cut away the portion that surrounded the radio and basically just made the divider thinnner . And to further get more height out of the radio opening I made the top wall of the bezel much thinner too . I didnt think id work , but I got the clearence I needed . Look at my pics really good at the bezel , and you see how the top wall and middle divider are are much thinner than on a stock bezel . Heres the rest of the run down .
Head unit - 2003 Vibe in dash 6-disc changer headunit , the same radio is in a toyota matrix , but it is a GM part . This the ONLY car u can get the new style GM double din radios out of . ALL other GM's with this head unit use class2 electronics and are powered by a PCM signal and not 12 volts . You can also use the Vibe Navagation head unit , IF you can find all the components for it . Youd need the antenna , theres 2 modules , the head unit and the navagation DVD .
Radio controls wiring harness - I figured out how to power the radio controls by looking at skematic from a 2003 grand am GT with the monsoon system and radio controls .
Rear plug - from the vibe , just spliced in correct wires .
I also used the 200 watt Vibe monsoon amp .
All and all I loved it . Im not a stereo guy , but I wanted something better than delco head unit in there without spending all kinds of cash .
I dunno if the aftermarket double dins will work or not as Im unsure of the dimensions . I will say though , on the GM head unit , I did have to shave down a portion the face plate on the top and bottom . Not much though , and the bezel totally covers it up .
Tell those guys at that custom shop to grow a set of ***** , lol . This was my first attempt at customizing like the this and I really didnt find it too hard to accomplish .
L8 man
Derek
Good luck.
Santino.//
