Headlight Problem...They turn on without the ebrake being down...
Old Oct 18, 2006 | 07:58 PM
317indy
Guest
Posts: n/a
Default Headlight Problem...They turn on without the ebrake being down...
I really miss the feature where they would turn on only if the ebrake was down. But now everytime I turn on the ignition at night, they come on. Is there a fuse or connector that I can look for to see if something is blown or broken.
Old Oct 18, 2006 | 10:24 PM
Divergent Lightning's Avatar
A fuse wouldn't be the problem there, but a bad switch. I would check the switch that is wired to the e-brake first.
Old Oct 19, 2006 | 07:11 AM
WhiteBird00's Avatar
Ungrounded Moderator
Does the "brake" light on the dash go on when you apply the parking brake? If not then either the parking brake switch is bad (as mentioned above) or the wire going to the switch is broken or disconnected.
