door panel speakers compatability??
Old Oct 20, 2006 | 09:01 PM
GXPPOWER's Avatar
Default door panel speakers compatability??
like i posted previously i have a new HU which is working wonders. sound is alot better. even with the rest of the monsoons sytem intact. now my question is. is their any speakers sold that can be direct replacement of our stock door panel speakers? or does only the generic GM ones that come stock compatible?
im debating wether to get a new set of the stock speakers or replace the door panel speakers with some that can handle bass alittle better.
Old Oct 21, 2006 | 03:10 PM
Mike02Z's Avatar
Only speaker I know off that would not require manual bi wiring is the Infinity Kappa 62.7i. You would still need to cut the factory connector off the factory speaker and wire that to the Kappa's. Lots of other speakers will fit in that spot but most will require some level of work to make them work right with the factory HU/wiring.
Old Oct 21, 2006 | 07:16 PM
todddchi's Avatar
It's a very easy process to use the Kappa's, you're snipping a connector off the factory speaker and wiring it up onto the Kappa while it is on a table or whatever.
If you can get the door panel off, you can do that. The fronts do pretty much everything in a vert... do it.
BTW my full set of vert speakers went for over $150 on eBay...
