amp install using stealth box
Old Oct 30, 2006 | 10:15 AM
99Transamls1's Avatar
Default amp install using stealth box
Can someone show me some pics of were you installed your amp at when using a stealth box. I am wanting to run a 12 in the stealth box. I want it to look as clean as possible (amp not showing) just box and sub. I was thinking about installign it behind the bax but I don't know id it is going to fit.
Old Oct 30, 2006 | 10:35 AM
MikeFbody's Avatar
Restricted User
no way an amp is going behind a stealth box.
most guys mount them on the rear wall. Like this:
Old Oct 30, 2006 | 01:36 PM
Yeah I knew most people mount them on the wall but i really wanted to hide the amp i am thinking of removing my spare and installing it beside my monsoon.
Old Oct 31, 2006 | 12:51 PM
Dal1as's Avatar
With a small amp that may work but none of the larger amps will fit back there with your spare in place. The car in the pic is mine and with the hatch shut the install is pretty stealth. The amps don't get in the way of the t-tops or storage at all. With the flap up you can't even tell I have an aftermarket stereo except for the head unit.
