Anyone running a three speaker system?
Would two quality door speakers, A 10 inch woofer, both amped and ran through my alpine deck, produce a great sound? I figure this set up would be pretty light weight, and more than enough for such a small car, but who knows..
A nice set of components up front, a little bit of dynamat around the driver and shoddy around the panel to keep it from buzzing. Then about 75-100 rms to each front.
A solid 4 channel amp probably makes the most sense for this type of setup, front channels to doors rear channels bridged to sub. THere are 5 million choices for 100x4 amps. Class D for the sub won't be necessary with such modest power levels.
And if you ever decide you want some rear fill then a cheaper set of coaxials driven off the head unit would be enough for fill.
I'm not looking to spend a **** tone of money, as I'm not looking for a KILLER sound, but what 4 channel amp, and what pair of front's would you guys suggest? Part number wise.. I also don't know much about watts, other than I do know the difference between RMS and Peak, but I have no clue as to how many watts RMS I should look for.
