Steering Wheel Controls not workin
Old Nov 22, 2006 | 11:50 PM
Yahelou's Avatar
Default Steering Wheel Controls not workin
The weirdest thing happened with the steering wheel controls yesterday. I have a Pioneer HU and I have the PAC thing installed. The volume button on the steering wheel stopped working. BUT everything else is working fine. It seems kind of weird that only the volume would stop working and not anything else. Hopin someone could give me some input.
Old Nov 23, 2006 | 12:41 AM
Formula350's Avatar
Switch took a crap
Old Nov 23, 2006 | 02:37 PM
Yahelou's Avatar
do u think that one of the fuses blew or something like that?
Old Nov 23, 2006 | 07:34 PM
WhiteBird00's Avatar
Ungrounded Moderator
No, all the steering wheel controls run off a single fuse. If the fuse had blown, none of the controls would work.
Old Nov 24, 2006 | 12:50 AM
Yahelou's Avatar
So something must be wrong with the PAC. How can I fix this?
Old Nov 24, 2006 | 01:00 AM
presto_z's Avatar
try reprograming it.. i had a problem where every button would do the same thing??? but i reprogrammed it and then it worked great..
i had the PAC SWI-X
Old Nov 26, 2006 | 01:01 PM
Yahelou's Avatar
damn thing is crazy. it justed started workin again by itself. didnt do anything. oh well, good thing its workin.
Old Nov 26, 2006 | 01:51 PM
sdm1234's Avatar
what is a PAC?
Old Nov 27, 2006 | 02:17 PM
JR HAWK 9's Avatar
same thing happened to my PAC SWI-X.....it would work on and off and it was almost always the volume buttons that had the problem. I looked into it and I am pretty sure it was a bad connection of the main "trigger" wire. I had used one of those cheesy wire tap things and decided to take it off and solder it instead and that cleared up the issue. I have since stepped up to the Pioneer version of the PAC seeing I upgraded head units. I would give that a try though, make sure your wire connections are secure and never use those stupid clip on wire taps.....they're useless!
Paul
Old Nov 27, 2006 | 07:52 PM
presto_z's Avatar
Originally Posted by sdm1234
what is a PAC?
the PAC SWI-X (or similar product) lets you use the steering wheel controls to control your aftermarket stereo....
Old Nov 27, 2006 | 09:23 PM
Firehawk526's Avatar
(2) things to check:
(a) make sure you don't have a blockage between the reader HU/sending unit PAC.
Mine is located in console but in reverse is obstructed
(b) Any light directly(i.e. sunlight) hitting the HU reading sensor will cause the PAC NOT TO WORK. (no reading)
Most likely a crimped wire or the interface unit has gone Ka-Ka
Old Jul 2, 2009 | 09:23 PM
ws6spd's Avatar
I had a similar prob recently...PAC installed with a Pioneer HU.
All buttons worked fine for 1 year and then the vol up button stopped working consistently. The vol down button also stopped working a couple times. All other buttons worked perfect.
I took the HU out and examined the wires and all conections were fine. I was suspecting heat causing the prob since the car was sitting outside in the sun everytime it failed.
I moved the PAC to a different spot behind the dash and we'll see.
I also suspect the blue/green wire connection as I used the cheap tap connection.
I will definitely be changing that if it acts up again.
Old Jul 6, 2009 | 10:39 AM
shoemike's Avatar
Check the ground on the PAC device, if it's intermittent funny things will happen.
