Ignition Wire Diagram Needed
Old Nov 23, 2006 | 08:08 PM
XpEdItIoUs's Avatar
Default Ignition Wire Diagram Needed
Anyone have a ignition wire diagram or if someone can tell me what each wire is for.
Old Nov 23, 2006 | 10:12 PM
XpEdItIoUs's Avatar
Anyone? what are the red,pink,brown,and yellow wires for?
Old Nov 24, 2006 | 09:08 AM
WhiteBird00's Avatar
Ungrounded Moderator
Here you go:
RED - input, battery power from junction box #2 on the left fenderwell
PINK - output, hot in RUN and START positions
YELLOW - output, hot in START position
ORANGE - output, hot in RUN position
BROWN - output, hot in RUN and ACCY positions
Old Nov 24, 2006 | 08:23 PM
XpEdItIoUs's Avatar
Originally Posted by WhiteBird00
Here you go:
Thanks, can you tell me where the outputs go to? all I know is:
Yellow - starter solenoid relay in electrical center #2, relay power by clutch pedal switch.
Pink - some where to elcetrical center
Orange - ?
Brown - ?
Old Nov 25, 2006 | 10:01 AM
Here are the major outputs:
Yellow - PCM, instrument panel and starter relay through STRTR fuse via clutch switch (M6) or neutral safety switch (A4).
Pink - IGN relay in junction box #2, PCM through PCM IGN fuse, ABS through ABS IGN fuse, instrument panel fuse box.
Orange - instrument panel fuse block for HVAC, DRL, turn signals, backup lights.
Brown - ignition power for BCM and retained accessory power, instrument panel fuse block for wipers and washer.
Old Nov 25, 2006 | 03:33 PM
XpEdItIoUs's Avatar
Thanks agian.
Old Mar 5, 2015 | 09:48 PM
cartelmoto's Avatar
I have a 65 impala doing a ls3 swap with pro charger. i don't have any idea how to wire the ignition. i have a purple wire that say starter solenoid a pink wire that say ignition feed and a brown wire. do i need to install some relays? sorry for being such a rookie.
