Stock alarm sensitivity?
Old Nov 28, 2006 | 12:00 AM
SPECIALIZED STAINLESS's Avatar
Default Stock alarm sensitivity?
I read a while ago that you can adjust the sensitivity on the stock alarms for Camaros... The search isn't working so anyone got some info it this? Thanks
Old Nov 28, 2006 | 12:37 AM
SweeTbone's Avatar
If it's anything like Birds, which is should be, there is an adjust **** on the shock sensor that is under the rear passenger side panel near the spare tire/jack. Turn the 3 plastic screws there to remove the panel, then you'll see the sensor. It's two sided taped to the body under that panel. There is a little white **** to adjust it. It's it is still "factory", there will be tape surrounding that **** that you'll have to break. It will take a little adjusting too. You don't want it too sensitive so that every little things sets it off.
Old Nov 28, 2006 | 01:04 PM
SSmokin99's Avatar
I'm going to make my alarm a lil bit more sensitive.
Old Nov 28, 2006 | 02:23 PM
2001NBMZ28's Avatar
Counterclockwise to decrease...clockwise to increase.
Old Nov 28, 2006 | 07:16 PM
Thanks guys. The seal on my shock sensor wasn't broken but it only took 1/4 of a turn to have it fully clock wise...
