need some speaker/amp advice
Old Dec 11, 2006 | 08:44 AM
burningsquirrels's Avatar
Default need some speaker/amp advice
My sail panel speakers blew in my 2001 Z28, and I'm thinking of using up some items that I already have. I did a lot of reading around on this forum and it sounds like JL 6W0's are the ticket for a budget fix to the problem, as I don't want to spend a lot of money for what I already consider to be a good sound system for my purposes.
Now, I could wire up the 6w0's just like how others directly connected Rockford Fosgate punch 4406's in the sail panels... but I looked at what I had in the garage and I have a 2x12" sub box with Pioneer IMPP(?) subs and a Rockford Fosgate Punch 250 A2 amp.
I was thinking, I could probably sell the box and subs to go towards a pair of 6w0's. Plus, since the 6w0's are 4 ohm, I could probably boost their power using the RF Punch 250 A2 amp. Kind of what Rouge Leader had but with 6w0's and the addition of an amp. Does this sound like a good setup?
If I went this route, I'm wondering where I could mount this amp (probably where the spare tire goes or in the opposite cubby hole). The other thing I would need help figuring out is how to wire this up. I was thinking the easiest way would be to take the wires from the HU going into the monsoon amp and split those to go to both the monsoon amp and the RF amp. Then on the outputs of the RF amp, wire those going back to the sail panel speaker wires after disconnecting them from the monsoon amp.
Does this all sound right? Or should I just forget the second amp and just plug the 6w0's straight in?
Thanks guys.
Old Dec 12, 2006 | 10:05 PM
Sk8runeg's Avatar
I believe the stock sail panel speakers, being factory subs, are 2 ohms not 4 ohms. Therefore, you would need a 2 ohm sub as a direct replacement. I found out a while ago that the 6.5 inch bazooka tube has 2 ohm speakers in it, and they will work as a direct replacement, but you cant buy the speakers themselves I believe, you would need to buy two tubes and take the speakers out.
Either way, they wond sound nearly as good as if you got a single 10" sub, a stealthbox, and the amp you got and used that with a line out converter if you got the factory radio.
-Scott
