window motor
Old Dec 16, 2006 | 03:06 PM
tunit's Avatar
Default window motor
Does anyone know how hard it is to put on a window motor for a 2001 Trans Am? I've also heard that aftermarket motors go out really fast after installing them...anyone have any suggestions? Thank you in advance!!
Old Dec 16, 2006 | 04:00 PM
VIP1's Avatar
Copy & Paste Moderator
Sticky:https://ls1tech.com/forums/wiring-stereo-electronics/303776-frequently-asked-questions.html
Specifically:https://ls1tech.com/forums/showpost....1&postcount=18
Easy to do.
Old Dec 16, 2006 | 04:59 PM
tunit's Avatar
hey thanks for the reply...now i dont have to pay labor!! just one more question...should i go with a motor from the dealer or just get a cheap aftermarket? aftermarket is about $70 and from the dealer is about $180...but one mechanic told me that his experience with aftermarket are horrible
Old Dec 16, 2006 | 05:22 PM
2001NBMZ28's Avatar
Get one from Auto Zone, cheaper than the dealer and has a lifetime warranty. Helped install several and they work fine.
Old Dec 16, 2006 | 07:55 PM
VIP1's Avatar
Many people on here recomend the seimans or dorman aftermarket window motor, which should both be available at AutoZone.
Old Dec 16, 2006 | 08:09 PM
tunit's Avatar
alright, ill give one of those a shot. i cant pull the pics up for the firebird...the camaro has the same setup correct?
Old Dec 16, 2006 | 08:17 PM
2001NBMZ28's Avatar
Yeah, the metalreviewcentre site went away for some reason...basically the same, except the switches on the door panel are a little different. You can do it, just take your time...after you've done it once you'll be an expert.
