Navigation System question?
Old Dec 25, 2006 | 04:43 AM
SRT2LS1's Avatar
Default Navigation System question?
Does anyone know if the factory navigation on some of the new GM cars/suvs fit into a T/A's radio slot or if there is enough there to work with to make one fit? Im sure it can be wired up just not sure about the fit, any help would be great . Thanks!
Old Dec 26, 2006 | 09:14 AM
WhiteBird00's Avatar
Ungrounded Moderator
You can make the newer double DIN head units fit a T/A with some dash modification (there are several threads on this that a search will find) but the wiring will be more than you expect. The newer head units don't have normal connections - they use class-2 serial data.
