Front speakers are not working?????
Old Dec 26, 2006 | 04:16 PM
99T/AMAN's Avatar
Default Front speakers are not working?????
My front speakers in my T/A have hardly any sound coming out and in speakers in the rear seat there is interferance from the antenna. Let me know what i can do to fix these problems.
Old Dec 26, 2006 | 10:20 PM
99T/AMAN's Avatar
bump!!!! no one has had a problem like this????
Old Dec 27, 2006 | 06:05 PM
HiTechGent's Avatar
Is this the stock Monsoon system or an aftermarket setup?
If Monsoon, have you altered any of the wiring?
Old Dec 27, 2006 | 09:16 PM
99T/AMAN's Avatar
completly stock system, haven't done any thing to it. When the power ant. is turned on there is the static in the rear speakers and now the front ones stopped working to.
Old Dec 28, 2006 | 12:37 PM
HiTechGent's Avatar
If both the front tweeters and woofers are dead, it likely means your head unit is bad (as the tweeters are driven directly from the HU, while the woofers are driven by the Monsoon Amp). The static from the power antenna also would implicate your HU as the problem.
This is assuming nobody has been messing around behind the center console and accidently screwed up the wiring harness to the head unit.
Old Dec 28, 2006 | 12:38 PM
sdm1234's Avatar
yea i have that same exact problem. i get noise occasionally when i hit the brakes, or use a turn signal. i would also like to know how to fix this... it's been like this for roughly 3 months now, but i'm too lazy to trace down the wiring and such.
Old Oct 26, 2007 | 10:45 AM
99T/AMAN's Avatar
Default speakers not working
Sorry it has takin so long to get back to this. I replaced my amp and that solved the whole problem, everything works good, now i just have to fix the blown speakers.
