Battery relocation question
Old Dec 29, 2006 | 12:04 AM
Jammer's Avatar
Default Battery relocation question
Okay, so I reloacted the battery to the trunk...do I need to run 3 seperate power wires..one to starter, one to alternator and one to fuse block? Or can they be spliced and run off one big wire? I have run a single 1 aut wire so far.
Old Dec 29, 2006 | 05:18 AM
Inspector12's Avatar
TT-TECH Veteran
You can do it either way as long as you have good conections. If it were me I would run one to the starter and one for the altenator and to power the fuse block. Ofcourse it is your choice and I know one wire looks cleaner so I would struggle with it for a little bit I would use a little bit smaller wire for the Alt/Fuse block though.
Old Dec 29, 2006 | 07:06 AM
anarchy99's Avatar
I spliced the wires together at the front of thr car. Worked fine for me, just used alot of electrical tape at the splice points.
Old Dec 29, 2006 | 11:50 AM
Richiec77's Avatar
Just run the 1/0 wire back to the front. Then use a junction box or a terminal to tie all the wires back together. Basically take the + post wires and connect them to the 1/0 wire by whatever means.
