Help harman/kardon drive + paly
what exactly do you want to know ? they are easy to wire up, tap into power, ground, and acc at the radio, and then it's just a matter of wiring the audio output of the drive and play box into the aux input of the head unit, and then mounting the controller and screen.
using the stock monsoon deck, you only options are fm transmitter or aux into a changer port adapter. But yes, either way, you need to pop the deck out, which is super easy in a fbody.
