CD Changer eject problems
Old Jan 3, 2007 | 01:53 AM
bww3588's Avatar
Default CD Changer eject problems
on my 98Z, every once in a while, my cartridge in my CD Changer will eject unexpectdly and i have to get back there and take it out, (because the door is still closed but its still trying to eject it.) and pull one CD tray out of the changer itself and put it back in the cartridge and put it back in the changer. what is the problem and how do i fix it. it seems to be happening when i go over a bump or get on it real hard. idk im sick of only being able to play CD's when my car says its ok.
Old Jan 3, 2007 | 08:54 PM
bww3588's Avatar
bump...........my laziness exceeds my desire to listen to music right now, so please help me avoid the trips to the back of the car everyother day.
Old Jan 3, 2007 | 10:13 PM
HiTechGent's Avatar
I've never taken my changer apart so this is just an educated guess.
But it sounds like the limit switch that senses when you open the cartridge door to initiate the eject sequence is faulty or has come loose. It should not be too difficult to fix.
Old Jan 4, 2007 | 12:41 AM
bww3588's Avatar
i wouldnt know where to begin.
Old Jan 4, 2007 | 08:49 AM
HiTechGent's Avatar
Sorry, I'm not about to take mine apart to give more detailed instructions. Unless it happens to break in the near future. lol
If you have friend who's good at tinkering with electronics, have him take a look at it. The switch in question should be fairly easy to identify.
If you can glean the part number (often ink-stamped on the part) you can probably find an exact replacement on the internet. Or, chances are it is a common enough type of switch that you can just remove it from the unit and take it down to Radio Shack or an appliance/electronic parts store and hand it to the clerk and get a usable replacement with no sweat.
Your other options are: A) Take it to a professional (Dealer/repair shop) and pay to have it repaired. B) Buy a replacement. or C) Make do without it.
My guess is buying a used replacement would be cheaper than taking it to GM dealer. And I am not sure if GM dealers even do electronics repair (I doubt it). I'd think a competant local stereo/tv/appliance repeair shop should be able to fix it for under $50 or so.
Old Jan 4, 2007 | 10:21 AM
bww3588's Avatar
ill take a peek at it and see what i can come up with.
