help looking for special product
Old Jan 6, 2007 | 10:58 AM
daniel6718's Avatar
Default help looking for special product
im looking for the cable for an amp, i plan to use a stealth box with a stock headunit and im wondering what options are out there, what do i actually need to hook it up?
i heard that you can splice into the stock sub wires and run it to the amp somehow, what do i need?
btw this is a 96z with bose
also ive seen somebody hook up their aftermarket speakers through the stock bose amps and they push them decently, is this worth it? and how do you hook the headunit to the stock amps, theres about 6 wires? or wait till i get a headunit and hook the speakers directly to that?
Old Jan 6, 2007 | 01:08 PM
2001bluerata's Avatar
Is it the actual bose box or a custom box? If custom you'll probably be better off getting an amp to support it vs. using the stock amp for a sub.
As far as hooking aftermarket speakers to the stock amp, it's a lot easier to do it that way then run all new wires to the headunit itself or to another amp.
Hooking an aftermarket headunit to the stock amp is as easy as buying a wiring harness and connecting it to together.
Hope this helps
